 Os males do Audio Digital…e como derrotá-los (em inglês)
4 participantes
Os males do Audio Digital…e como derrotá-los (em inglês) Empty
MensagemAssunto: Os males do Audio Digital…e como derrotá-los (em inglês)   Os males do Audio Digital…e como derrotá-los (em inglês) EmptyQua Jan 29 2014, 15:29
The Unique Evils of Digital Audio
And How to Defeat Them
By John Siau August 2010
na língua original:
http://www.benchmarkmedia.com/discuss/feedback/newsletter/2010/08/1/unique-evils-digital-audio-and-how-defeat-them
http://www.benchmarkmedia.com/discuss/sites/default/files/unique-evils-digital-audio.pdf (PDF)
tradução (low-fi) do google:
http://translate.google.com/translate?sl=en&tl=pt&js=n&prev=_t&hl=pt-PT&ie=UTF-8&u=http%3A%2F%2Fwww.benchmarkmedia.com%2Fdiscuss%2Fsites%2Fdefault%2Ffiles%2Funique-evils-digital-audio.pdf
MensagemAssunto: Re: Os males do Audio Digital…e como derrotá-los (em inglês)   Os males do Audio Digital…e como derrotá-los (em inglês) EmptyQua Jan 29 2014, 15:50
Resumo dos conteúdos:
Harmonic Distortion is Dominate in Analog Systems
Some Analog Systems Suffer from IMD – More Audible than THD
Digitally-Induced Distortion often Resembles IMD
Unique Causes of Distortion in Digital Systems – The “Evils” of Digital
“Evil” #1 - Jitter
Jitter Causes Phase Modulation
Some Digital Systems have Audible Jitter-Induced Distortion
Killing Jitter
“Jitter-Free” Playback is Possible
Jitter in Recordings Cannot be Removed
Evil #2 - Quantization Errors
Staircase Analogy
Staircase, Hill, and Laser Pointer – A walk inside of an A/D converter
Too Many Cups of Coffee – A solution to the quantization distortion problem
Killing Quantization Distortion with Dither – Musical Details are Saved
Killing Quantization Noise with More Bits
Killing Quantization Noise with High Sample Rates
A 1-bit Digital Experiment – try this at home
Sony’s DSD Systems Hides Quantization Noise at Ultrasonic Frequencies
High Sample Rates Provide More Space to Hide Quantization Noise
Noise Shaping – If you can’t get rid of the noise, just hide it!
Noise Shaping Has Improved the Quality of 16-bit CD’s
A Better Solution – Increase Both the Sample Rate and the Bit Depth
1-bit Works, 16-bits Work, Why 24?
Evil #3 - Aliasing
Wagon Wheels and Old Movies - A Foreshadowing of Future Problems
Like Movies, Digital Audio Systems can have Aliasing Problems
Attempting to Kill Aliasing with High Sample Rates
Killing Aliasing with Low-Pass Filters
In a CD system, we must filter out all signals above 22.050 kHz while attempting to leave audible frequencies untouched. We would like to pass 20 kHz without loss while removing 22 kHz. This is a very difficult task, and it requires a very abrupt low-pass filter. In the early days of digital audio, these “brick-wall” filters were analog filters. Unfortunately, it is very difficult to build analog filters that have the necessary performance. Consequently, many early recording and playback systems suffered from some audible aliasing problems, and/or some loss of frequency response.
It is much easier to construct a brick-wall digital anti-alias filter. Converters can be configured to “oversample” at some multiple of the desired sample rate. A brick-wall digital filter can be applied when the audio is down-sampled to the desired output sample rate. A very simple analog low-pass filter must still be used to remove very high-frequency signals from the input of the oversampled converter. Virtually all digital audio systems now use over sampled A/D and D/A converter. Aliasing is rarely a problem in these newer “oversampled” audio converters.
Low-pass filters are applied in the A/D to prevent aliasing. Low-pass filters are applied in D/A converters to remove sampling artifacts and produce a continuous waveform that has no evidence of passing through a sampled system. End-to-end, a digital audio system can be indistinguishable from a band-limited analog system.
Quantization distortion can be completely eliminated with dither. The number of bits, the sample rate, and the type of dither employed will collectively determine the SNR of the digital transmission system.
Jitter-induced distortion can be reduced to levels that are well below audibility. Many newer recordings are essentially jitter-free. If reproduced through a low-jitter D/A converter, jitter-induced distortion will not even approach audibility.
Aliasing has been virtually eliminated through the use of oversampled converters. No audible aliasing artifacts should exist in a well-designed 44.1 kHz system.
The audio industry has produced thousands of CD titles that include all 3 of the “digital evils” at audible levels. These older recordings do not accurately represent the capabilities of the CD system. Clearly the CD format has not delivered “perfect audio forever”, but it can now deliver “nearly perfect audio”. We haven’t followed the wrong path for 28 years; it has just taken us that long to perfect the system. Few commercial recordings reach the performance that is achievable with the CD format. For this reason, 44.1 kHz 16-bit systems still remain a viable distribution format for high-quality recordings. While the CD format is well-suited for distribution of the finished product, Benchmark does not recommend this format for recording or production use as the quality degrades rapidly when processing is applied.
In theory, the DSD system can offer a slightly better signal to noise ratio than a noise-shaped CD system. It can also provide a slightly wider usable bandwidth. Unfortunately, neither of these capabilities may be realized in a recording that was completely recorded and produced in DSD. DSD relies on very aggressive use of noise shaping, and consequently, it is even less robust than the CD format in a production environment. DSD 1-bit signals are not easy to process and quality can degrade quickly in mixing and mastering operations. For these reasons, Benchmark does not recommend DSD for production use. We believe that DSD recordings usually fail to deliver the benefits claimed for the format.
High-resolution 96 kHz 24-bit systems are essentially artifact-free when properly designed. All distortion and noise artifacts can be held well below audibility in these systems. These high-resolution digital systems can capture, store, process, and reproduce analog signals without a hint of quantization, jitter, or aliasing. These systems have sufficient resolution to tolerate many stages of digital processing and are ideally suited for recording, production, and distribution.
MensagemAssunto: Re: Os males do Audio Digital…e como derrotá-los (em inglês)   Os males do Audio Digital…e como derrotá-los (em inglês) EmptySex Jan 31 2014, 13:07
Faz mais de 30 anos, que o "mal" do digital é conhecido!...
Faz mais de 20 anos que ele é debatido!!!...
Faz mais de 10 anos que é combatido!!!...
Mas continuo à espera da MUSICA!!!...   Os males do Audio Digital…e como derrotá-los (em inglês) 707387
Até+
PS: Pura provocação, mas com uma boa pincelada de verdade...
MensagemAssunto: Re: Os males do Audio Digital…e como derrotá-los (em inglês)   Os males do Audio Digital…e como derrotá-los (em inglês) EmptySex Jan 31 2014, 14:23
Depreendo que continuas à espera da Musicalidade…da "assinatura" sonora dos equipamentos analógicos.
Isso obtém-se facilmente com este plug-in:
Os males do Audio Digital…e como derrotá-los (em inglês) 2uf35w1
Twisted Evil
MensagemAssunto: Re: Os males do Audio Digital…e como derrotá-los (em inglês)   Os males do Audio Digital…e como derrotá-los (em inglês) EmptySex Jan 31 2014, 14:34
Twisted Evil
Musicalidade e "assinatura",... não tém nada a ver!... mas
obrigado a sério pelo "plug-in", andava à procura de um bom à uma data e este pareçe compléto!... logo digo
vai haver "experimentações", com as minhas cobaias (amigos!!! Embarassed )!!!...
PALUSE
PALUSE
MensagemAssunto: Re: Os males do Audio Digital…e como derrotá-los (em inglês)   Os males do Audio Digital…e como derrotá-los (em inglês) EmptySáb Fev 01 2014, 00:40
Twisted Evil
 Os males do Audio Digital…e como derrotá-los (em inglês) 317942 Os males do Audio Digital…e como derrotá-los (em inglês) 265963 lol! Os males do Audio Digital…e como derrotá-los (em inglês) 933723
O Ricardo é mesmo "bera".
E faz mais de 40 anos que os fabricantes continuam a usar fontes de alimentação de "caca" e estágios analógicos de "trampa" nos equipamentos digitais. Depois esperam que "aquilo toque " alguma coisa de jeito?
Vão-se catar!!!
 Os males do Audio Digital…e como derrotá-los (em inglês) 43034
 Os males do Audio Digital…e como derrotá-los (em inglês) 936335
Mas confesso-vos, que depois de ter adaptado umas borrachinhas no suporte do motor do Xpression 2, apertado o eixo e ajustar o "tilt" do motor com a correia instalada, que a sonoridade com a Ortofon VMS 20E MkII com a carga a 62KOhms//450pF total, está a tomar conta do meu interesse imediato com uma boa série de discos.O "rumble" está bem mais atenuado, mas as prensagens é que são uma grande porra!
 Os males do Audio Digital…e como derrotá-los (em inglês) 809774
MensagemAssunto: Re: Os males do Audio Digital…e como derrotá-los (em inglês)   Os males do Audio Digital…e como derrotá-los (em inglês) EmptySáb Fev 01 2014, 01:48
PALUSE escreveu:
..mas as prensagens é que são uma grande porra!
Compra prensagens boas.  Os males do Audio Digital…e como derrotá-los (em inglês) 933723
Digital Audio - Like Reassembling A Cow From Mince  Os males do Audio Digital…e como derrotá-los (em inglês) 6xxboo
PALUSE
PALUSE
MensagemAssunto: Re: Os males do Audio Digital…e como derrotá-los (em inglês)   Os males do Audio Digital…e como derrotá-los (em inglês) EmptySáb Fev 01 2014, 03:06
PALUSE escreveu:
 Os males do Audio Digital…e como derrotá-los (em inglês) 447836
Vens-me dizer que prensagens Mofi, AP ou Imakustik são consideradas "beras"?
Bom, eu é que não tenho pachorra para vigarices, nem me vou pôr a jeito a comprar um "front end" que disfarce o mau trabalho de terceiros que é pago ao peso da grama do ouro de 999/1000!
No passado apanhei algumas exemplares, mas das últimas ditas "audiófilas", algumas que apanhei são "barrete", não pelo som mas pelo estado do nível interferências e ruído de superfície. Há edições antigas com vinil maleável que dão para traz a muitas das novas.
Lamento pela Mofi, o som é bestial, mas de resto... e pelo preço, não dá mesmo.
 Os males do Audio Digital…e como derrotá-los (em inglês) 271350
MensagemAssunto: Re: Os males do Audio Digital…e como derrotá-los (em inglês)   Os males do Audio Digital…e como derrotá-los (em inglês) EmptySáb Fev 01 2014, 03:11
PALUSE escreveu:
PALUSE escreveu:
Eu disse boas, não disse caras.... Os males do Audio Digital…e como derrotá-los (em inglês) 936335
PALUSE
PALUSE
MensagemAssunto: Re: Os males do Audio Digital…e como derrotá-los (em inglês)   Os males do Audio Digital…e como derrotá-los (em inglês) EmptySáb Fev 01 2014, 03:33
[Eu disse boas, não disse caras.... Os males do Audio Digital…e como derrotá-los (em inglês) 936335
Nos produtos em que a qualidade da matéria prima, a manutenção dos equipamentos de produção, o asseio e a precisão no processo de fabrico é requerido para obter qualidade, o custo mais elevado é sine qua non, caso contrário é um aproveitamento de uma moda sem a evolução merecida ou requerida, oferecida pela janela de tempo que existiu até à retoma da tendência do mercado.
 Os males do Audio Digital…e como derrotá-los (em inglês) 22692
MensagemAssunto: Re: Os males do Audio Digital…e como derrotá-los (em inglês)   Os males do Audio Digital…e como derrotá-los (em inglês) EmptySáb Fev 01 2014, 09:40
PALUSE escreveu:
Amigo Paluse, existe muito vinil de elevada qualidade e enormes prensagens onde tudo foi bem feito mesmo sem serem edições luxuosas (caras). Obviamente que também existem prensagens de grande qualidade a preços elevados, o que não é de estranhar, senão estaríamos na presença de uma verdadeira burla, o que também pode acontecer.
MensagemAssunto: Re: Os males do Audio Digital…e como derrotá-los (em inglês)   Os males do Audio Digital…e como derrotá-los (em inglês) EmptySáb Fev 01 2014, 09:55
PALUSE escreveu:
Vão-se catar!!!
Concordo plenamente: o Digital não é apenas 1s e 0s, há a conversão D/A, a filtragem, o andar de saída, o grounding … o modo como estes elementos são implementados afectam e muito a "transparência" e "castram" o desempenho.
O que leva de volta a este tópico:
https://www.audioanalogicodeportugal.net/t5230-modificacoes-ou-optimizacoes-de-equipamentos
» Tudo sobre Audio Digital (em inglês)
» Conceitos de Audio (em Inglês)
» Pedido de aconselhamento - Áudio Digital
» Como o digital está a ficar vintage estou apostar no mesmo!
» Audio Digital
Áudio Analógico de Portugal :: Digital-
