Ave_Rapina Membro AAP
Mensagens : 73 Data de inscrição : 27/03/2014
| Assunto: Phono MM/MC Battery Operated Dom Dez 28 2014, 15:52 | |
| New project on development. Phono MM/MC Battery Operated with selectable input impedance and capacitance with LCD GUI interface and three buttons for user interface. Power supply is outside the box.
Soon will be posted drawings.
Further info: valente.olimpia@gmail.com | |
Mário Franco Membro AAP
Mensagens : 2494 Data de inscrição : 27/03/2013 Idade : 66
| Assunto: Re: Phono MM/MC Battery Operated Dom Dez 28 2014, 16:00 | |
| अवधारणा मैं मूल जब तक बहुत दिलचस्प लगता है और सब कुछ है कि कुछ हो सकता है लेकिन अभी तक के अलावा अन्य कुछ रखा जाएगा | |
Mister W Membro AAP
| Assunto: Re: Phono MM/MC Battery Operated Dom Dez 28 2014, 23:08 | |
| - Ave_Rapina escreveu:
- New project on development. Phono MM/MC Battery Operated with selectable input impedance and capacitance with LCD GUI interface and three buttons for user interface. Power supply is outside the box.
Further info: valente.olimpia@gmail.com Sorry but there should be a misunderstanding or something I did not catch... If it is battery operated what is the power supply for? | |
| Assunto: Re: Phono MM/MC Battery Operated Seg Dez 29 2014, 14:32 | |
| - Mister W escreveu:
Sorry but there should be a misunderstanding or something I did not catch... If it is battery operated what is the power supply for? You need to charge the batteries occasionally. | |
| Assunto: Re: Phono MM/MC Battery Operated Seg Dez 29 2014, 14:35 | |
| - Mário Franco escreveu:
- अवधारणा मैं मूल जब तक बहुत दिलचस्प लगता है और सब कुछ है कि कुछ हो सकता है लेकिन अभी तक के अलावा अन्य कुछ रखा जाएगा
Translations on Google normally loses the meaning of the sentence/paragraph. | |
Mister W Membro AAP
| Assunto: Re: Phono MM/MC Battery Operated Seg Dez 29 2014, 16:05 | |
Ok, I see. I thought it was a phono stage (like others on the market) with ordinary batteries (non-rechargeable). | |
| Assunto: Re: Phono MM/MC Battery Operated Ter Dez 30 2014, 18:08 | |
| Forgot to refer that is fully balanced and floating input to reduce noise. | |
| Assunto: Re: Phono MM/MC Battery Operated | |
