 Antique Sound Lab
Antique Sound Lab Empty
MensagemAssunto: Antique Sound Lab   Antique Sound Lab EmptySex Jun 10 2011, 18:22
ASL MG-SI15
Vendo este magnifico integrado, single ended.
350€(devo estar cos copos)
http://www.audioasylum.com/reviews/Integrated-Amplifier-Tube/Antique-Sound-Laboratory-Limited/MG-Si15/amp/14265.html
http://www.preference-audio.de/mgSi15.html
http://www.affordableaudio.org/ASL-MG-SI-15-DT.pdf
http://www.preference-audio.de/pdf/mg15si.pdf
The MG SI 15 incorporates a single ended class ‘A’ topology with triode and pentode operation. Utilizing one KT88 per channel, the MG SI 15 can produce 5 wpc in triode mode and 15 wpc in pentode mode. Since those watts are tied to a class A / tube configuration, they should go a long way towards driving an appropriate pair of speakers.
The integrated amp features an external bias adjustment with calibrated bias meter as well as an all new line level output for a subwoofer – great for those wanting to tap into the lower octaves. Overall frequency response is from 13 Hz to 77 kHz (+/-1dB), distortion at 1W is <0.6% and SNR at full power is >78dB. Input impedance is 100K and loudspeaker output impedance is standard at 8 Ohm. Dimensions are 13 x 10.5 x 9 (WxDxH in inches) and the unit weights in at 29 lbs.
The MG SI 15 integrated tube amplifier is available for MSRP: $1200.00 U.S.
fotos retiradas da net
[img]Antique Sound Lab 42555510[/img][img]Antique Sound Lab Antiqu10[/img][img]Antique Sound Lab 42919210[/img]
MensagemAssunto: Re: Antique Sound Lab   Antique Sound Lab EmptySeg Set 26 2011, 19:45
Novo preço
325€
Antique Sound Lab 424293
Contacto por MP ou:
joao-militao@sapo.pt
Antique Sound Lab
» The Sound
» Antique Sound Lab aq 1001
» antique sound lab aq-1007 (construido pelo sr. Rui Pinho)
»  Antique Sound Labs WAVE 8
» What is Sound?
Áudio Analógico de Portugal :: Classificados :: Classificados / Arquivo-
