 Active Noise Cancellation (Heads)
Ave_Rapina
Data de inscrição : 27/03/2014
Active Noise Cancellation (Heads) Empty
MensagemAssunto: Active Noise Cancellation (Heads)   Active Noise Cancellation (Heads) EmptyQua Ago 20 2014, 14:51
One of the major problems of Headphones is the cheap and noisy plastics and the weak ambient noise isolation that contaminates the sound being reproduced by the speaker.
Headphones with systems to cancel this are normally expensive and the results somehow don't reflect the payed price.
In order to bright the best of two worlds is in developing and active noise cancellation the takes active part on the system.
For information: this is not only an phase shift with microphone picking up noise.
The stage is working with long life lithium-sulfur batteries that are charged with an simple adapter when there is need to do. After charged, it disconnects automatically until an certain threshold is reached and reconnected again up to full charge.
Some initial photos: (project on the go)
Active Noise Cancellation (Heads) A5f2fl
Further info: valente.olimpia@gmail.com
Ave_Rapina
MensagemAssunto: Re: Active Noise Cancellation (Heads)   Active Noise Cancellation (Heads) EmptySex Ago 29 2014, 14:45
Some more advances:
Active Noise Cancellation (Heads) 2pzfp1d
Futher info: valente.olimpia@gmail.com
Ave_Rapina
MensagemAssunto: Re: Active Noise Cancellation (Heads)   Active Noise Cancellation (Heads) EmptyDom Set 28 2014, 17:46
Some more advances:
Active Noise Cancellation (Heads) 2psorh1
Further Info: valente.olimpia@gmail.com
MensagemAssunto: Re: Active Noise Cancellation (Heads)   Active Noise Cancellation (Heads) EmptySeg Set 29 2014, 21:30
Parece interessante! Active Noise Cancellation (Heads) 22692 Eu cá prefiro outro tipo de abordagem. Para mim, quanto menos interferências no sinal melhor, e se for preciso tentar melhorar os materiais, prefiro arriscar nesse sentido.
Ave_Rapina
MensagemAssunto: Re: Active Noise Cancellation (Heads)   Active Noise Cancellation (Heads) EmptyQua Out 01 2014, 17:17
Some more advances:
Active Noise Cancellation (Heads) 16jk2uc
» Lowest-Noise RIAA Phono-Amps:Designer’s Guide
» Active Pre-Amplifier with Digital Supervision and Balanced Inputs and Outputs
» White Noise
» Signal-to-noise ratio MC vs MM
» Lt3045 ultra low noise power supply
